M2 and S3d Machine Control
Posted: Thu May 19, 2016 1:33 am
by scampa123
I had something strange happen today. I believe my USB hub failed, which made me unable to connect to my M2...When I finally figured out what it was, I changed out my hub...
I'm now able to connect to my M2 via S3D using their Machine Control Panel, however I cannot control the M2! I cannot do anything...I tried Octoprint, and I seem to be able to connect and control the printer that way...but I needed to use S3D because my long print stopped when using Octoprint....So I plan to print from the SD Card in the printer, but now I am unable to tell S3D to start my print from SD...
Here is what I see in the console for S3d:
Attempting connection at \\.\COM3...
RECEIVED: start
Connected to machine!
SENT: T0
RECEIVED: echo: External Reset
RECEIVED: Marlin 1.0.0
RECEIVED: echo: Last Updated: Mar 5 2016 12:40:58 | Author: (none, default config)
RECEIVED: Compiled: Mar 5 2016
RECEIVED: echo: Free Memory: 4141 PlannerBufferBytes: 1232
RECEIVED: echo:Hardcoded Default Settings Loaded
RECEIVED: echo:Steps per unit:
Steps per unit:
RECEIVED: echo: M92 X88.88 Y88.88 Z400.00 E471.50
RECEIVED: echo:Maximum feedrates (mm/s):
RECEIVED: echo: M203 X500.00 Y500.00 Z25.00 E25.00
RECEIVED: echo:Maximum Acceleration (mm/s2):
RECEIVED: echo: M201 X4000 Y4000 Z100 E10000
RECEIVED: echo:Acceleration: S=acceleration, T=retract acceleration
RECEIVED: echo: M204 S2000.00 T3000.00
RECEIVED: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
RECEIVED: echo: M205 S0.00 T0.00 B20000 X8.00 Z0.40 E5.00
RECEIVED: echo:Home offset (mm):
Home offset (mm):
RECEIVED: echo: M206 X0.00 Y0.00 Z0.00
RECEIVED: echo:PID settings:
PID settings:
RECEIVED: echo: M301 P25.89 I1.94 D86.53
RECEIVED: echo:SD card ok
SENT: M105
SENT: M105
SENT: M105
SENT: M21
SENT: M20
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
Disconnected.
Emergency stop issued! Attempting to reconnect...
RECEIVED: start
SENT: T0
Steps per unit:
Home offset (mm):
PID settings:
SENT: M105
SENT: M105
SENT: M21
SENT: M20
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
Disconnected.
RECEIVED: start
SENT: T0
Steps per unit:
Home offset (mm):
PID settings:
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
SENT: M105
Has anyone had this behavior before? I tried reinstalling S3D, but it didn't fix it...
Thanks!!
