cosi wrote:
I don't have use the blue tape, it was suggested to me by another user/post. I will take it off and do as you suggested with the hairspray. I have also adjusted the temperatures as advised.
If you remove the blue tape, you
might need to reset the gap between the nozzle and the plate for the first layer. You can just spray the hairspray right on top of the blue tape for now. Re-set the gap later when you get the PEI sheet installed.
I did some research on the PEI surface but unsure what thickness to buy, is that supposed to replace the glass altogether? Any ideas where to buy it from, I have found some on Amazon.
This PEI sheet:
http://www.amazon.com/gp/product/B0013H ... ge_o04_s00
This tape to attach it to the glass:
http://www.amazon.com/TapeCase-squares- ... VRQQCX5H5J
This tool to cut the PEI:
http://www.amazon.com/Hyde-Tools-45730- ... utter+tool
These are the instructions for attaching the PEI sheet:
Start peeling the liner off of 1 side of the tape by slooooowly pulling the liner off one side of the full 12 inch sheet while holding the corner down flat, and doubling the liner back on itself sharply. It's impossible to describe with words, but it's a technique used by vinyl cutters to apply vinyl transfer tape and there is a
video of it below. It's all in the peeling.
After you have removed one side of the tape liner, lay the tape on a flat desk, sticky side up. Lay the glass down on it. Cut the excess tape from around the glass with an exacto knife. Turn the glass over and brayer the tape down and pop the bubbles in the tape with an exacto knife through the remaining liner, before you pull it off. (Small slashes cut into the remaining liner to let the air out.)
Get it as flat as you can before removing the remaining liner on the tape, using the same technique you used before, to keep from pulling the adhesive off the glass.
Remove one liner from the sheet of PEI, and lay that side facing up on the desk. Flip the sticky side of the glass facing down, and set the glass down on the exposed PEI surface. Press down well. Use the plastic cutter to score the PEI around the glass
deeply. Flip the whole thing over and carefully score (using a straight edge) on the other side of the PEI, trying to line up your score marks with the ones underneath. Keep scoring until you can snap the PEI away from the glass.
Sand the edges, remove the top liner on the PEI,
scuff the top of the PEI sheet with fine sand paper (1000 grit) and you're done.
Video showing the peeling technique :
https://www.youtube.com/watch?v=r-PRVLEaDRY
Also, what height should the hot end be from the bed?
0.13mm -0.15mm when the nozzle and bed are heated to printing temps, with a correctly calculated Z-Offset, determined by using the calibration square method that Ed described for you.
If you have not done so, please read the Beginner's Guide (all of it) for your machine here: viewtopic.php?f=3&t=3342.
The troubleshooting section will save you a lot of waiting for answers, since most of the problems you've run into so far are discussed there, along with suggested fixes. There are about six things you need to do to get the machine set up correctly, and skipping any one of them can cause a lot of wasted time. (And the guide was likely published after you got your machine, so you might not have known about it if you didn't hang around on the forum.)
