Is it fine to regularly print at 270º with the V4?
This eSun white PETG I have has bad layer bonding unless I print it at 265º+. Just want to confirm, I won't be doing damage to the V4 at this temp correct?
Re: Is it fine to regularly print at 270º with the V4?
Nope....should be fine.
Rick has confirmed the operating temperature of the V4 PTFE is 300C.kartcrg wrote:This eSun white PETG I have has bad layer bonding unless I print it at 265º+. Just want to confirm, I won't be doing damage to the V4 at this temp correct?
Safe operating temperature, not failure temp?insta wrote:Rick has confirmed the operating temperature of the V4 PTFE is 300C.kartcrg wrote:This eSun white PETG I have has bad layer bonding unless I print it at 265º+. Just want to confirm, I won't be doing damage to the V4 at this temp correct?
Thanks man! Now I remember seeing that thread.insta wrote:viewtopic.php?f=2&t=3204
I wonder if there is a way to increase the LCD screen preheat limit past 260º..
