Heated bed troubles
Posted: Tue Jul 12, 2016 11:31 pm
Hi,
I've not been using my 3-D printer much at all lately due to being busy with other things, but when I came back to run a project, I noticed that the bed wouldn't heat up.
When I fired it up, everything works fine. The hot end heats up fine, but the bed does not. The M2 I have has the old (outdated and need to replace) double power supplies, has the z stepper motor that heats up to 500 degrees Celsius when printing (an exaggeration, but pretty darn hot), and is not painted matte black like the newer ones but rather just a stainless steal frame.
So, here's the catch.
When I tell S3D to heat up the bed, the red light on the Rambo for the heated bed doesn't light up indicating that the heated bed is getting power. I believe this to be a problem with the power cable connection in the back - it's loose and the male connector pops out easily (even with the cord in a relaxed position). Wiggling the connector slightly (if you hit the sweet spot) lights up the LED, but as soon as you take the pressure off of the connector, the bed (and sometimes the entire machine) becomes disconnected from being powered at all.
So, what do you suppose I could do to remedy this problem?
Thanks in advance!
Thanks in advance!
