Under extruding help
Posted: Sat Jul 16, 2016 7:18 pm
I'm having some under extruding issues that I can't figure out. I'm hoping it's something simple that I'm missing. I've been printing for the last year and a half with very few issues. About a week ago the printer started under extruding. When a print starts it lays down about 5mm of nice thick line and then it thins to almost nothing. Occasionally it'll print what looks like a beaded necklace, evenly spaced little blobs with a very thing string connecting them.
This happened at around the same time I upgraded to Windows 10, but I think that's just a coincidence. I use Simplify 3d to create the gcode, upload it to octoprint and kick off the print from there. I've tried uploading previously good gcode to octoprint and printing but get the same issue, taking Windows 10 out of the equation.
I removed the nozzle, heated it with a torch and ran guitar string through it, then ran cleaner filament through it and still have the same issue. If I extrude into the air it seems to extrude fine, the extruded plastic measures 0.45mm which I think is where it should be. I can speed it up and it appears to keep up just fine. I'm printing with PETG with the settings from this forum. My target temp is 247C, but if I check the temp of the insulation around the heater block it's showing about 160C, is that right?
I've also tried connecting my laptop directly to the printer and printing from S3d. No difference. While printing I tried turning the extrusion override dial up to 150% and there was no difference. I've tried PETG and ABS, no difference.
Any suggestions on things to try? I'm running out of hair to pull out.
Thanks
Tom
Thanks
Tom
