SD Card Cable Orientation
Posted: Wed Sep 07, 2016 2:35 pm
by sonra
Hi
I by mistake disconnect the cable from board . I have a cable with 6 color wires . try to find in manuals the right way to plug the cable .
it will be nice to have how to connect on the other side to the reader connector
Regards Doron
Re: SD Card Cable Orientation
Posted: Wed Sep 07, 2016 3:41 pm
by sthone
Which end did you unplug the end going to the Rambo or the end going to the actual card reader?
If it's the end going to the card reader (attached to the lid)... Looking from the front the Red wire goes on the left side. (Keep in mine this is on the old plastic electronic boxes, I'm not sure if it changed on the metal enclosure. )
Edit-Since they changed the website I can''t find the old Kit instructions anymore. :cry: but..... You can just see the connector at the top of this picture.
Posted: Fri Sep 09, 2016 2:47 pm
by sonra
thanks
It is on the other side (the Rambo side ) . I think I have a problem with the interface board . I tried to connect it in the 2 posibble ways . With no success in getting the reader to work. Does any has the electronic scheme of this board ??
Posted: Fri Sep 09, 2016 2:57 pm
by sthone
http://reprap.org/wiki/Rambo_v1.3 (I think that's the right version :? )
Posted: Fri Sep 09, 2016 3:51 pm
by sonra
Thanks .I meant the sd card interface board and not the Rambo
Posted: Sun Sep 11, 2016 12:45 am
by willnewton
