Hey guys, who has bowed down gantry's? I'm talking the x-rail here where the print head sits on.
I've been chasing a level build plate for a few days now, and thought I had a bowed glass, always high in the center, but I busted out my straight edge rule I use in my garage for checking engine block and head warp, and verified the glass plate is flat. Method of checking is you put a known straight edge on a surface, bust out the feeler gauges and see which and where it slides in between. Glass was less than .001" very good if you ask me. The gantry, not so much, I get about .006" (.152mm) of space in the middle of the gantry at the aluminum plate and on top the x-rail. Searching turned up to be belt tension, so I loosed the belt completely, and it was still showing .006" gap. I loosed all the bolts to the x-rail and tighten it back up again, still have a gap. Is it possible that over time, the gantry got flexed permanently? This is the first time I've touched the belt tension since I got the M2 shipped to me about a year ago. Always seemed fine when I checked.
What's the fix for this? shims? if so where? under the x-rail, the aluminum plate? or the plate and the steel frame? Logic says between the rail and the aluminum plate? I'm going to do more measuring and taking the x-rail off later this week and see what I can come up with here.
Let me know, thanks!
Bowed Gantry?
Re: Bowed Gantry?
I had something similar. Diagnosed it with a taper gauge between the nozzle and a pretty flat MIC6 plate. I just shimmed the middle of the X rail by however much the bed was "high" and that got everything flat. I tried not to loosen all the hardware, though. Left a screw on each end mostly tight so I didn't have to worry about messing with the squareness of the rails. It sounds like you're past that point now, so I'm not sure what that's gonna do to ya. I've been thinking about making a print up to check and calibrate squareness, but I'm temporarily printerless, so that'll have to wait a bit.
Re: Bowed Gantry?
yes the rail needs a couple shims under it. goes directly under the rail. very common issue
Re: Bowed Gantry?
alright. I think I got it all squared away, not sure if it was the best, but I put a a .006" shim in the center and had to progressively put smaller shims going out. Putting a single shim in the center gave me almost like a "W" shaped rail when the screws where all tightened up. I'm down to .0015" in one spot now, and perfectly okay. Leveling on the borosilicate glass is WAY better now. Anyone care to share how they are shimming? Just the middle section? or throughout till its flat? Perhaps just screw in the two end screws and one in the middle? or less torque on the screws in between? Just throwing out ideas in my head. Let me know, thanks!
Re: Bowed Gantry?
If you think there is a problem, please contact support. We have a jig that we can send out that you can use to reset the axis.
Rick
Rick
Re: Bowed Gantry?
Huh, ok, I'm printing fine right now, not too concerned about squareness yet, but I'll give you guys a call just in case I missed something. Thanks Rick.
