Bowed Gantry?
Posted: Wed Nov 02, 2016 11:21 am
Hey guys, who has bowed down gantry's? I'm talking the x-rail here where the print head sits on.
I've been chasing a level build plate for a few days now, and thought I had a bowed glass, always high in the center, but I busted out my straight edge rule I use in my garage for checking engine block and head warp, and verified the glass plate is flat. Method of checking is you put a known straight edge on a surface, bust out the feeler gauges and see which and where it slides in between. Glass was less than .001" very good if you ask me. The gantry, not so much, I get about .006" (.152mm) of space in the middle of the gantry at the aluminum plate and on top the x-rail. Searching turned up to be belt tension, so I loosed the belt completely, and it was still showing .006" gap. I loosed all the bolts to the x-rail and tighten it back up again, still have a gap. Is it possible that over time, the gantry got flexed permanently? This is the first time I've touched the belt tension since I got the M2 shipped to me about a year ago. Always seemed fine when I checked.
What's the fix for this? shims? if so where? under the x-rail, the aluminum plate? or the plate and the steel frame? Logic says between the rail and the aluminum plate? I'm going to do more measuring and taking the x-rail off later this week and see what I can come up with here.
Let me know, thanks!
