control board issue I think
MagicEngineer
I think my control board has bit the dust. How can I tell for sure? Simplify3D cannot communicate with the printer and there are no lights lit on the board at any time. Also I checked the fuse and it is good.
Re: control board issue I think
Most likely a CPU failure. I had a different, (non-M2), printer die like that. I replaced the CPU, and it works fine.
MagicEngineer
That was the other possibility I was thinking of. I actually ordered both because I need to get it running again asap and it can't hurt to have spares. I was hoping someone might know a quick method of troubleshooting between the two, but that was before I decided to order both. Now I will just plug in the new power supply and if it still doesn't work I will replace the board.Phil wrote:Most likely a CPU failure. I had a different, (non-M2), printer die like that. I replaced the CPU, and it works fine.
MagicEngineer
No I did not. I didn't know about the other two. Turns out shorting the f3 brings it back to life. Any idea where I can get that style of fuse?
MagicEngineer
Actually I posted too soon. It gives me lights and fans but still no communication. I am running it with a fused jumper. When I attempt to connect I get the typical stopping of the fan but the connection still fails. I think we have successfully determined that it is the board, but i am worried that a short somewhere else might have blown the fuse and damaged the board.
MagicEngineer
I received the new board and it is all hooked up. I can now communicate with the printer again but I have a new issue. When I home z it rises to the top and immediately drops while the motor continues to whine. I have to hit emergency stop to shut off the motor. The light on the z stop micro switch is lighting so the switch is good but apparently the board is not getting the message. Any ideas?
MagicEngineer
I thought I figured it out. The connector that appears to connect the z mico switch to the board has an adjacent connector to its right. I turned the plug around and plugged it into that socket. It seemed to work and homed properly. However when a print begins the build plate drops to the bottom and tries to print from there. everything else seems to be fine.
What was the problem? .... it might help someone out in the future with the same issue.MagicEngineer wrote:Nevermind I figured it out
MagicEngineer
I was wrong I didn't figure it out
