Extruder temp sensor issues and clogs?
Posted: Tue Jan 17, 2017 6:12 am
I've printed several rolls of various materials since buying my m2 about a year and a half ago without ever a single clog. My favorite has been ESUN PetG and never had any issues with the black or magenta colors
Bought my first roll of white and about half way through it I start getting clogs almost every other print. Except the nozzle doesn't seem to be clogged. The filament gets all bound up near the hole just below the extruder gear. After clearing that I can push filament through the nozzle no problem.
I thought at first I must have the tension screw too tight causing it to deform the filament and making it too large to fit through the hole. Every time I took it apart to clear the clog I noticed the temp sensor was loose and not pushed in all the way...but wasn't sure if that was normal or not and didn't think much of it.
Now today, it stops printing mid print and i notice I'm not getting any temp readings from the sensor.
Do you think it's likely my clogs were actually due to a failing temp sensor causing the nozzle to cool down and jam the filament?
Any suggestions for troubleshooting the issue? Should the sensor have been loose like it was and able to slide in and out?
