Rambo failure?
Posted: Tue Jan 17, 2017 7:53 am
by eclarkmeyer
I'm pretty sure that the relay output for the bed heater has failed. For no reason that I can tell it just stopped working. Can I configure the board to use a different relay or am I going to have to buy another Rambo? I've had the printer for a couple of years now but I haven't used it enough that I would expect a failure.
Re: Rambo failure?
Posted: Tue Jan 17, 2017 4:24 pm
by sthone
Did you check the wiring at the bed (common failure spot) and or fuses first?
Re: Rambo failure?
Posted: Wed Jan 18, 2017 5:10 am
by eclarkmeyer
Thanks for the comment! It got me to looking at the cable that runs to the bed and I found where the wire loom had been melted?!? After I cut the tie-wraps and removed the loom I found that the wire had actually burned in two before the power connector. Desoldered the connector, clipped back the wires, resoldered and now I'm back in business. :D
