Weird noise coming from makergear M2 printer?
Nofear202
Post by Nofear202 » Wed Feb 01, 2017 3:21 am
It's coming from the box the Rambo is in. I have to reset it or turn it off twice. I did a YouTube video of it.
Link: https://m.youtube.com/watch?v=qUq4VQHyuXU
3dPrintingMD
Re: Weird noise coming from makergear M2 printer?
Post by 3dPrintingMD » Wed Feb 01, 2017 3:23 am
Sounds like there is some junk in the fan. It happens when stuff falls into the fan opening.
Nofear202
Post by Nofear202 » Wed Feb 01, 2017 8:46 am
There's nothing in the fan. I just have to reset or restart the 3D printer once or twice. Then it works with out the weird noise.
13brv3
Post by 13brv3 » Wed Feb 01, 2017 1:15 pm
That's almost certainly the fan. Sometimes they make that noise when the bearings start to go out. Next time it's making the noise, tap the center of the fan and see if it stops, or at least changes tone momentarily. The good news is that the fan is easy to replace.
Cheers,
Rusty
RolandW
Post by RolandW » Sun Mar 01, 2020 5:29 pm
Have you been able to isolate the cause of this? My M2 makes a similar noise every now and then on startup. I find it hard to believe that it's the fan because it never does it any other time. If the fan were worn out it seems like the noise would occur at other times too since it runs for hours on end. It happens only when powering up. If I turn it off, wait a few seconds, and power up again, it's fine.
Post by airscapes » Mon Mar 02, 2020 3:54 pm
To determine if it is the fan, just stop the fan with your finger or any solid object and see if the noise stops.. It will not hurt anything. I get ABS stuck in there all the time during nozzle prime.
Gwhite
Post by Gwhite » Mon Mar 02, 2020 9:59 pm
When bearings fail, they will start making noise when they are cold. As they warm up, the metal expands, the lubrication flows better, and they will stop making noise (for a while). Over the years, I've had all sorts of fans that scream briefly on start up. For the ones that can be lubricated, a drop of oil shuts them right up. Most DC fans aren't designed for lubrication, but as mentioned, they are easy to replace.
