echo: cold extrusion
MY Maker Gear M2 single head, heated bed printer with most recent software keeps stopping early in the print. We bought the printer Sept. 28th 2016, and it has been working great. No issues... Until now. When I run a print, sliced on Sli3r, I am getting cold extrusion prevented errors. The pronterface software is indicating that the nozzle temp is fluctuating. It will be at normal temp, then drop dramatically (I've seen it drop as low as 105) then bounce back up to 220. If I click set temp every time I see the temp drop, the print will keep going, but if I don't stand there a set temp every time it drops, eventually the print stops with the error message "re set temp and use M999 to re start when temp is re set. I can't get through any prints using the proterface connection, or printing it from the SD card. Is there a new firmware version out? Can I re-set the printer? How can I re-load the current firmware to "Re-Boot ' the printer?
Re: echo: cold extrusion
This is a loose / broken thermistor. It is a relatively common problem and is easily fixed with a new thermistor. Skip straight to that step
Where do I get a new thermistor? Is this under warranty?insta wrote:This is a loose / broken thermistor. It is a relatively common problem and is easily fixed with a new thermistor. Skip straight to that step
That should be under warranty -- email support @ makergear.com.
