Play in Y-axis bearing
Posted: Wed May 31, 2017 2:23 pm
Hello,
I have an M2 and was wondering how I would remove the play in the Y-axis linear bearing? I can see what appears to be adjustment screws on each end but wanted to make sure before I ruin anything. I'm also not sure how to tell which end has the play.
Also, my Rambo box cooling fan is dying and I have a ball bearing fan of the same physical size that could work but it is 12v. 0.8 watts vs. the original 12v. 0.15 watts. Would the difference in wattage be a problem?
One last thing, I've noticed the M3 has a swivel clip that now holds the glass plat to the bed, is there a way to adapt that to the M2? The spring clips are such a pain!
Many thanks,
Steve
Many thanks,
Steve
