Heat Set Insert for Ikea Camera Mount
I am printing Steve's ikea camera mount from thingiverse.
https://www.thingiverse.com/thing:1691549
I am not familiar with heat set inserts or where to get them locally. Fastenal?
Thanks,
Jerold
Thanks,
Jerold
Re: Heat Set Insert for Ikea Camera Mount
McMaster-Carr has them. The heating irons and tips are on the right-hand columns of each size.CCRN wrote:I am not familiar with heat set inserts or where to get them locally. Fastenal?
Although they're intended for heat or ultrasonic setting, that requires far more precision / equipment / fussing than seems reasonable. I make the hole a snug fit for the insert's OD, butter it up with epoxy, and shove it in place.CCRN wrote:heat set inserts or where to get them locally
Works like a charm:
https://softsolder.com/2017/04/28/badge ... eel-mount/
Get 'em from Amazon in two days or from eBay in two weeks. Search for (knurled brass insert) and away you go.
Some measurements and observations on eBay inserts:
https://softsolder.com/2016/02/03/knurl ... c-inserts/
https://softsolder.com/2016/02/16/knurled-inch-inserts/
I get my heat set inserts from Mcmaster.
Just a heads Up.... If you're going to print that just double check the light you have both of of mine have a tapered base pieces at the bulb head where my mount clamps on but I've been told some lights have a straight piece there so it might not work.
Ok, Amazon is great. Now I just have to figure out the size I need. Steve wrote on thingiverse he used 2/56" screws. The female end where it would go measures 3mm wide by roughly 5mm deep.
I am thinking this one would be about right and would love some confirmation before I order.
https://www.amazon.com/uxcell-M2x4mm-Em ... rt+m2+x4mm
Thanks,
Jerold
Thanks,
Jerold
sthone wrote:I get my heat set inserts from Mcmaster.
My light has the taper in it. Which item should I order from McMaster? There is a lot there.
Here's the Specs to the ones I used.
Thanks. That helps me.sthone wrote:Here's the Specs to the ones I used.
Looks like the "Thread Fit" spec is different.
