Leveling way out
webrider
Leveling way out
Post by webrider » Sun Aug 13, 2017 5:55 pm
I am fairly new, but have been printing for 5 months. I decided to change the Kapton tape on the glass plate because it had some nicks from removing prints. After replacing the Kapton on the glass plate with the new Kapton I decided to check the bed leveling. What I discovered was front to back on the left side was pretty good with just minor adjustments of the corner screws. The rigth side front and back corners were way out and I had to be adjusted it quite a bit. Now the glass on the right side corners a real high compared to the left side. It was even difficult to rotate the corner cam that hold the glass down. The right rear cam would not rotate over the glass and I had to loosen the screw in the cam in order to rotate it over the glass. I rechecked the height and it looks good. Prints though are not real good. I printed the Makergear Bracelet and it looks fine. Can you help about the drastic adjustment.
