Hey guys. I own 3 M2s and one of them that I just got last week is making this weird noise when printing... It's hard to describe, sounds like something is rubbing and resonating... None of others printers make this sound. I took video of it just now, you can hear it around 2 and 7 seconds: https://youtu.be/cI127ICedBY
I can't pinpoint where it's coming from...
What could it be?
Weird noise from brand new M2 Rev E
Re: Weird noise from brand new M2 Rev E
Are you talking about the honking noise it makes? Many of mine make it too -- I suspect it's skipping/dithering microsteps, because it gets much worse when lowering the current to the motor drivers in the firmware. If anybody can nail down a real reason, I'd be interested in testing it out.
Yeah, "honking"! LOL
Does Rambo board have pots to adjust stepper current or it can only be done via software? Thanks for the idea!
It's only in the firmware. It's inside of Configuration_Adv.h.
- willnewton
It seems to occur a bit before a direction change? I just had a quick listen, as it loud where I am. My first thought was to wonder if it was an oddity in the code from the slicer.
Is it just this printer? Do the others print the same model on duplicate settings honklessly?
If they all do it, at least you can isolate it somewhat to the code.
Does changing the print speed by 10% slower or faster lead to any dehonkination?
It might just be an odd bit of resonance.
Might be having a few steps honked off or motor doing some crazy cogging Hänkenyodelen during deceleration.
Yeah I'm pretty sure it's not G-Code. Happens on any print I run on this printer, very easy to replicate honking
I does sound like something resonates, I'll try tightening fan grills, but also sounds like maybe needs oiling. Might put a bit of lithium grease on the railings...
Speaking of weird noises, my other M2 upon finishing print lowers it's print bed very fast and it makes a soul-wrenching howl which terrifies my wife and my dog lol. I might take video of that that one, although I know that's it's definitely something on the z-axis
That's the Z stage falling. It's not *great*, but it's pretty harmless.bratan wrote:Yeah I'm pretty sure it's not G-Code. Happens on any print I run on this printer, very easy to replicate honking
I put this in my ending GCode:
Code: Select all
G1 X205 Y250 F2000
G1 Z200
M84
M104 S0
M106 S0
M140 S0
Ha, one I'm using is very similar
M104 S0 ; turn off extruder
M140 S0 ; turn off bed
G91 ; relative mode
G1 Z20 ; lift 20mm
G90 ; absolute mode
G1 Z200 ; drop Z axis to just above spring
G1 Y200 ; present part forward
G1 X30 ; move extruder to left side
M84 ; disable motors
M106 S0 ; stop bed fan
M108 S0 ; stop extruder and electronics fans
