remove baked on Pla from nozzle?
jferguson
Post by jferguson » Sun Apr 15, 2018 1:02 pm
I was punished for not sufficiently tightening the nozzle after cleaning by the Pla oozing out and covering it and then bakinbg on. I was able to get it off and replace it with a new one, this one installed more snuggly.
But how to get the baked-on Pla off?
How about boiling it in a pot for a while?
or possibly burning it off in our spare toaster oven -- in the garage? Or torching it off?
Or?? Any suggestions?
Gwhite
Re: remove baked on Pla from nozzle?
Post by Gwhite » Sun Apr 15, 2018 2:23 pm
I believe torching it off is traditional. I have a brass one soaking in "Zar Paint and Varnish Remover" which is 90% methylene chloride (very nasty stuff). It loosened a lot of it, but it didn't dissolve it as quickly as I had hoped.
I have found that the stainless steel nozzles seem to clean up much easier. Once PLA gets cooked onto the brass, it's pretty tenacious. The stainless just wipes off with a cotton swab.
Post by airscapes » Sun Apr 15, 2018 4:03 pm
I use one of these https://www.harborfreight.com/catalogse ... icro+torch
use a pair of vice grips (very loosely do not distort the nozzle, should not need force to lock them) and heat of the nozzle till the pla is ash.
jferguson
Post by jferguson » Sun Apr 15, 2018 7:35 pm
Nozzle is brass. I have a small pfopane torch, sounds like the way to go.
Is there a good reason to use brass nozzles when stainless seems more resilient?
Gwhite
Post by Gwhite » Sun Apr 15, 2018 9:22 pm
Brass is probably a slightly better thermal conductor, so it might maintain temperature out to the tip a bit better. As a practical matter, I doubt you could tell the difference, but more experienced users may have more info.
Post by insta » Tue Apr 17, 2018 3:31 pm
Brass prints "better". I can hit higher speeds and a bit less stringing.
jferguson
Post by jferguson » Wed Apr 18, 2018 12:07 am
Good to know. Thanks much Insta.
zemlin
Post by zemlin » Wed Apr 18, 2018 4:48 pm
Gwhite wrote:Brass is probably a slightly better thermal conductor
by about 9x over 303 stainless. The difference is not slight.
