Bed heat not working after replacing thermister wire
Vandal968
Post by Vandal968 » Mon Aug 27, 2018 8:24 pm
The thermister wire for my bed heat died a while ago (1+ year). Since I was busy, I just slapped some glue stick on the bed and kept printing with heat off, the bed temp readout used to flip between ambient and 0 while printing which helped me confirm that it stayed broken. Two weeks ago, I finally got around to investigating. I found the bad spot in the wire and replaced the entire thermister wire from Rambo to bed. Thermister readings have been nice and stable, but I hadn't tried to use the heat until yesterday. Nothing. I pulled the bed heater and plugged it into a bench supply and it draws power. I started checking the Forum to troubleshoot and came across a message that says:
"If the bed temp drops to zero which should be a bad thermistor or wire, then the firmware will disable bed heating altogether as a safety measure." -sprior
Located in this thread: viewtopic.php?t=169
Is that true? And, if so, now that my thermister is fixed how can it be reset?
thanks,
c
Vandal968
Re: Bed heat not working after replacing thermister wire
Post by Vandal968 » Mon Aug 27, 2018 8:50 pm
Ok, if a thermistor reading of zero disables bed-heat as stated above, then it's only for that session. I just pulled my rambo cover and hooked up a meter, turned on bed-heat, got 24v. jumped between the rambo terminal and the bed connector and the bed heat works. That wire must have failed as-well :(
Good news is that wire is cheap. While I'm at it, has anyone found a good solution for these bed-heat wires like drag-chain, etc? It seems like the one weakness of the MakerGear design.
cheers,
c
