strange print
sonra
strange print
Post by sonra » Mon Jul 29, 2019 10:41 am
Hi guys
I got 2 questions referring 2 pics attached
1) what is the case of some waves shown in print ?
2) the wires that are printed on bottom side of the print ( i use raft in the print )
Regards Doron
Re: strange print
Post by ednisley » Mon Jul 29, 2019 5:40 pm
All of the surfaces and perimeter threads look like crap, so I'd check for an extrusion problem.
Have you calibrated the slicer's Extrusion Multiplier with the actual filament diameter and measured thin-wall square thickness?
Is the filament drive gear securely mounted on its shaft? A loose gear can cause baffling retraction problems, but the intermittent globs suggest there's something wrong with the drive.
Is the motor pinion driving the gearbox worn to a frazzle? You must dismount the gearbox from the motor to check, so do that when you check the drive gear.
If all that checks out, then some other problem may be in play, but it sure looks like extrusion from here.
sonra
Re: strange print
Post by sonra » Mon Jul 29, 2019 10:52 pm
thanks
will check and see
Doron
sonra
Re: strange print
Post by sonra » Fri Aug 16, 2019 12:30 pm
Hi
checked slicer's Extrusion Multiplier with the actual filament diameter and measured thin-wall square thickness and got the almost the some results for all walls (+-0.5 mm) is it good or not ?
Disassemble into parts the extruder motor I don't find any problem i attach pictures maybe you can see something I don't notice
Thanks ahead Doron
sonra
Re: strange print
Post by sonra » Fri Aug 16, 2019 12:39 pm
of course I mean +- 0.05 mm and not 0.5 mm (
Doron
Gwhite
Re: strange print
Post by Gwhite » Fri Aug 16, 2019 9:07 pm
I typically get +/- 0.01 mm on my cal cube walls once I have the extrusion multiplier set right. The first wall thickness can often be off a little depending on retraction settings & the like, but 3 out of 4 should be pretty spot on.
Gwhite
Re: strange print
Post by Gwhite » Fri Aug 16, 2019 9:08 pm
sonra
Re: strange print
Post by sonra » Fri Aug 16, 2019 10:52 pm
Hi
Do you use Simplify software as your slicer . If yes can you send the profile you use
Thanks Doron
Gwhite
Re: strange print
Post by Gwhite » Sat Aug 17, 2019 1:27 am
I use S3D, but I'm packing to go out of town for a week. I didn't see what brand, or material you are using. If you are printing ABS for example, I have no profiles for that because I don't use it. I mostly print with eSun PLA+, which requires a different profile from regular PLA.
If you tell us what you are using, maybe somebody else can provide a profile. You can also check out the filaments sub-forum.
sonra
Re: strange print
Post by sonra » Sat Aug 17, 2019 10:05 am
Hi
I am using HatchBox 1.75 mm PLA will like to get good profile for S3D printer
regards Doron
