echo: cold extrusion prevented
gwendyl
Post by gwendyl » Sun Oct 11, 2020 9:38 pm
Hi all!
So starting about a month ago, my printer has started quitting mid print. MakerGear M2. Right before it quits, I get a series of "echo: cold extrusion prevented" errors, followed by :
[ERROR] Failed to set power settings:
Traceback (most recent call last):
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.pronsole", line 1173, in startcb
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.power", line 130, in powerset_print_start
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.power.osx", line 72, in inhibit_sleep_osx
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.power.osx", line 49, in AssertionCreateWithName
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.power.osx", line 40, in StringToCFString
AttributeError: 'module' object has no attribute 'kCFStringEncodingASCII'
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.pronsole", line 1180, in endcb
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ.pyz/printrun.power", line 134, in powerset_print_stop
File "/Users/craigvanvliet/Desktop/PyInstaller-2.1/pronterface/build/pronterface/out00-PYZ[/code][/code].pyz/printrun.power.osx", line 79, in deinhibit_sleep_osx
Early on, I did research into this and deduced that it was a failed thermistor. I can see the temperature jumping all over the chart. However, I have replaced the entire hot end and the problem continues.
Additionally, now, my build plate will not heat up. Related? Coincidental?
Any suggestions for next steps in diagnosing would be very appreciated!
- Gwen
Re: echo: cold extrusion prevented
Post by airscapes » Sun Oct 11, 2020 9:52 pm
Time to start checking for broken wiring in the harness and loose connections from end to end..
