How to stop the heating bed at s3d
jccdesign
Post by jccdesign » Thu Jul 10, 2014 1:05 am
Hi i want to use blue tape , but dont know how to stop the bed from heating
Re: How to stop the heating bed at s3d
Post by jsc » Thu Jul 10, 2014 1:07 am
When you run a print, the temperatures are baked into the gcode file when you prepare to print. Edit process settings, temperature tab, then click on Heated Bed. Remove all the setpoints.
jccdesign
Post by jccdesign » Thu Jul 10, 2014 1:12 am
i tried and it says " each temperature is required to have at least one poit definition"
jccdesign
Post by jccdesign » Thu Jul 10, 2014 1:14 am
ok so i have to create a new layer set point instead of saying 1 60 , create one that says 1 0 ?
Post by jsc » Thu Jul 10, 2014 1:17 am
Hm, never really noticed that before. Maybe it's new. Or maybe I just never tried it.
You can remove the Heated Bed controller entirely, or you can set it to a value below room temperature. 0 should work, if your room temp is above that...
jccdesign
Post by jccdesign » Thu Jul 10, 2014 1:25 am
ok i set the set point 1 0, and it worked
