I have the M2 with 24v power supply, 24 volt extruder. I've installed the latest firmware for the Viki from the Makergear wiki site. I have sent Makergear images of my wiring connections and they have confirmed it is wired correctly.
The issue I'm having is that when I power on the M2 the Viki LCD just flashes once quickly and then nothing. Makergear sent me a replacement and it does the exact same thing. So I'm thinking its either a firmware issue or a Marlin board problem. The printer is less than a month old, so it has the newest board.
If I re-flash the Marlin board to the standard firmware the printer continues to work fine. But when I flash with Viki LCD version of software I just get the flash on the LCD and end of story.
This is what I get from the printer when powered up with Viki firmware:
Code: Select all
*start*
*echo:Marlin Marlin 1.0.0 for M2 with LCD; 24V with 24V/40W hotend*
*echo: Last Updated: Jul 13 2014 10:50:25 | Author: (none, default config)*
*Compiled: Jul 13 2014*
*echo: Free Memory: 3986 PlannerBufferBytes: 1232*
*echo:Hardcoded Default Settings Loaded*
*echo:Steps per unit:*
*echo: M92 X88.89 Y88.89 Z400.00 E471.50*
*echo:Maximum feedrates (mm/s):*
*echo: M203 X200.00 Y200.00 Z25.00 E25.00*
*echo:Maximum Acceleration (mm/s2):*
*echo: M201 X7000 Y6000 Z100 E1000*
*echo:Acceleration: S=acceleration, T=retract acceleration*
*echo: M204 S3000.00 T3000.00*
*echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate
(mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z
jerk (mm/s), E=maximum E jerk (mm/s)*
*echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00*
*echo:Home offset (mm):*
*echo: M206 X0.00 Y0.00 Z0.00*
*echo:PID settings:*
*echo: M301 P25.89 I1.94 D86.53 *
