After unpacking, I followed the instructions that came with it step by step. Watched and followed the initial setup, z stop calibrating, bed leveling, and feeding filament videos by MakerGear. Per the instructions, I started printing tallthin.g that is on the SD card that MakerGear included with it. I'm using Simplify 3D-- I opened the machine control panel, clicked 'print from SD card', selected tallthin.g, and it started printing.
Print came out good but after closer inspection I noticed it didn't come out as good as the sample print MakerGear included in the box. I've attached pics-- blue is the sample print from MakerGear, black is my print.
Here are the issues I see...
1. There's a noticeable "gap" between the inside and outside walls. I say "gap" because I can push my fingernail in there and the PLA spreads apart.
2. Due to 1, the whole piece is more flexible than the blue one. Blue one is stronger/more sturdy overall.
3. There's a line that goes up the middle of one flat side. This is through the whole print from the bottom to the top. Thing is, the line starts at the bottom in a corner where two flat sides meet. Over the next 3cm on the Z axis, it zigzags until it gets directly into the middle of the flat side and stays in the middle for the remaining 15cm (guessing) height of the piece. The pic I attached shows how it starts at a bottom corner and moves to the middle.
In Simplify 3D, I changed the process settings from medium quality to high quality (only thing I see that the quality setting changed was infill from 20% to 30%) and reprinted. Didn't make a difference-- piece came out the exact same. During the print I was thinking-- would changing process settings in S3D effect print quality when printing an already made .G file off an SD card or do those settings only apply when you use S3D to slice and/or print directly to the printer?
What can I do so tallthin.g prints exactly like the sample print from MakerGear? I'm waiting to print anything else until I figure this out. Don't want to waste filament if this is going to possibly effect other prints.
Also-- any recommendations on some good beginner 3D printing guides? Something that has best 3D printing practices so I don't start getting in bad habits. Explanations of print settings and how they effect quality.
Thanks for the help! Please reply fast because I want to PRINT STUFF!
