Viki LCD Install on V4
3dPrintingMD
Post by 3dPrintingMD » Wed Oct 14, 2015 4:00 pm
Hi All - I just wanted to ask before I get into it.
Going to add the Viki LCD to the printer. MY main concern is the firmware. I'm assuming that I should just follow the instructions on the wiki site.
Anything I need to be aware of ?
3dPrintingMD
Re: Viki LCD Install on V4
Post by 3dPrintingMD » Fri Oct 16, 2015 4:45 am
Could use a hand here.
Did an LCD install. Everything seems fine, I have yet to do a print, but I noticed when I home my axis, the Z homes to the bottom of the machine verse the top, it seems like the Z axis is reversed.
Thoughts on this ?
Post by insta » Fri Oct 16, 2015 4:50 am
Flip the Z axis homing direction in the firmware -- you probably have the newest firmware (with a bottom endstop) on a machine with a top-mounted endstop.
3dPrintingMD
Post by 3dPrintingMD » Fri Oct 16, 2015 4:57 am
Thanks for the quick reply, I need more help than that, sorry.
How is that accomplished ?
3dPrintingMD
Post by 3dPrintingMD » Fri Oct 16, 2015 5:04 am
I should also clarify, I received a Geetech LCD from Makergear.
I'm dead in the water now, not sure how to edit firmware.
Post by jsc » Fri Oct 16, 2015 6:12 am
Did you change the stepper wiring at all? Perhaps you have one of them put in backwards? To flip a four wire stepper, either flip the wires on one group or swap the two groups of two without changing their orientation.
3dPrintingMD
Post by 3dPrintingMD » Fri Oct 16, 2015 6:18 am
No I literally did nothing.
Opened case, removed SD Reader, put interface card over correct headers, pushed in place, attached the 2 ribbon cables, and closed box.
PcS
Post by PcS » Fri Oct 16, 2015 12:56 pm
http://makergear.wikidot.com/m2-firmware
Please look at the link it should have the info you need . If you need more help after that let us know .
3dPrintingMD
Post by 3dPrintingMD » Fri Oct 16, 2015 1:15 pm
Followed this 100%.
The firmware is bad, if you open it,you will notice settings for mendel that are not what they say it should be.
3dPrintingMD
Post by 3dPrintingMD » Fri Oct 16, 2015 2:42 pm
Black z motor needs different firmware than what is currently on website.
This is per mg.
They will update soon.
