Z depth calibration
Z depth calibration
I've had my M2 for a while and bought the v4 extruder a while back. My month for my v3b broke and I decided to just go ahead and install the v4. I have and leveled my bed but I think the z depth is off. On my prints the filament isn't sticking to bed but gathering around the tip like a rat's nest. I adjusted the z stop using a card to where the nozzle just started to catch on it but it is still doing the rat's nest around the nozzle head. Any suggestions?
Jason Powell
http://www.kyphur.com
Re: Z depth calibration
Yeah, the Cold Set method using a business card is unfortunately the least accurate method. (Different thicknesses of cards.)
If you have a set of Metric Feeler gauges, set the Z-stop using a gauge of from 0.15 mm to 0.20 mm, while the nozzle and bed are at printing temperatures.
(It's a heck of a lot easier now to set the Z-Stop for the V4 nozzles if you have a gauge - you don't have to mess with the Z-stop bolt any more.)
We've got it written up in the Beginner's Guide (which is not just for beginners) - The Z-Stop is Item number 6 in the guide.
viewtopic.php?f=3&t=3342
After you have reset the Z-Stop, it's very important to adjust the starting point using the Z-Offset, as written up below:
viewtopic.php?f=3&t=3124
Those two steps will get you an excellent starting point for your prints.
Thank you! I'm going to have to go out to the garage and get my feeler gauges now!
Jason Powell
What do you mean with the V4? Just how less bulky it is? Can you adjust the nozzle height?Jules wrote: (It's a heck of a lot easier now to set the Z-Stop for the V4 nozzles if you have a gauge - you don't have to mess with the Z-stop bolt any more.)
Jason Powell
No, it has to do with the mount for the V4 and the shape of the hot end. If you will read in that guide - there is a separate Hot Set method for the Z-Stop on V4 nozzles. Much easier.kyphur wrote:What do you mean with the V4? Just how less bulky it is? Can you adjust the nozzle height?Jules wrote: (It's a heck of a lot easier now to set the Z-Stop for the V4 nozzles if you have a gauge - you don't have to mess with the Z-stop bolt any more.)
Yeah, after posting that I went through them and got the printer up and working. Did a calibration test and setting up a couple of other things right this second.
Jason Powell
Yes, thank you for all your help. It is greatly appreciated.
Jason Powell
