How do I print
scottfinchum
How do I print
Post by scottfinchum » Sat May 21, 2016 12:45 am
I just received my MakerGear. Set everything up - no problem. Leveled bed - ok. Test print - OK
Now how do I print? I am using Simplify3D. I am connected. The bed temp is 70ºC. with a red light in the Settings panel lit. The extruder is not lit. It's temp is 25ºC. g-code says m:104 invalid extruder
Any help out there?
Scott
Re: How do I print
Post by Jules » Sat May 21, 2016 10:09 pm
Which version of the machine have you purchased? Did you buy it from MakerGear or second hand? (Your first few posts are moderated on the forum, don't be surprised by delays.)
scottfinchum
Re: How do I print
Post by scottfinchum » Sat May 21, 2016 10:24 pm
Thanks for the response. I figured it out. Just a bit of a learning curve for the software.
Scott
Re: How do I print
Post by insta » Mon May 23, 2016 8:50 pm
scottfinchum wrote:Thanks for the response. I figured it out. Just a bit of a learning curve for the software.
Scott
Don't be that guy -- post what the setting was and what you changed it to! You're not the only person who's ever going to experience that issue!
