Motors/filament drive not working
Learner17
Post by Learner17 » Fri Oct 20, 2017 5:40 pm
Fan work, printer gets connected, temperature met at target but nothing moves, nothing prints. please help.
Printer is now online.
echo:Marlin: 1.0.0 RC2 for MakerGear M2, 24V with 24V/40W heater
echo: Last Updated: 2012-05-30 | Author: johnny
echo: Free Memory: 4775 PlannerBufferBytes: 1232
echo:Using Default settings:
echo:Steps per unit:
echo: M92 X88.88 Y88.88 Z400.00 E471.50
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z250.00 E200000.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z30 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum xY jerk (mm/s), Z=maximum Z jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:PID settings:
echo: M301 P25.89 I1.94 D86.53
echo:SD card ok
SENDING:M84
SENDING:M84
Setting hotend temperature to 0.000000 degrees Celsius.
Setting hotend temperature to 185.000000 degrees Celsius.
Setting bed temperature to 60.000000 degrees Celsius.
Setting print speed factor to 100%.
Extruding 6.000000mm of filament.
Reversing 6.000000mm of filament.
SENDING:G0 X100.0 Y100.0 F3000
Print started at: 09:02:44
[ERROR] Printer is currently printing. Please pause the print before you issue manual commands.
Print paused at: 09:23:29
SENDING:M84
SENDING:M84
SENDING:M84
SENDING:M84
SENDING:M84
jk42
Re: Motors/filament drive not working
Post by jk42 » Mon Oct 23, 2017 5:59 pm
Have you checked to see if your 6-pin power connector is fully seated? It is possible to connect and heat your bed and hotend and not have any motor function.
I that doesn't help, please contact us at support@makergear.com. We would be happy to assist you!
~Jason from MakerGear
