I've only done one of the pre-sliced example prints which was the keychain and it came out fine, but that's not very technical. I'd like to be able to import the settings from one of those pre-sliced ones and try the benchy with that, but I'm not quite sure how to import settings in S3D from a gcode file. I know you can do that in Cura so I'm guessing you can in S3D as well.
I'm not sure what the auto configure settings in S3D are. I'm totally new to S3D -- I've been using Cura up until now. When I got my machine I went to the Makergear Zendesk site and downloaded the S3D profiles and used those. Is there something else in S3D I need to do? As for speed, it was at the normal or default -- not "Nice" or "Fast". I *BELIEVE* the temperature was actulally pretty low -- 190 or 200 -- but I could be wrong. I'll double check when I get home.
I'm not sweating it either way. I'm pretty confident this thing will print like a dream once I get it dialed in a bit more. I've only been 3d printing for like 10 days now. I started with a maker select plus/duplicator I3 Plus and did every available upgrade which required me to take the machine apart down to the bolts pretty much. I'm learning fast, but there's always room to improve.
