Printing Multiple Vases
Re: Printing Multiple Vases
If you work front to rear, there's actually not much clearance you need - just the fan, basically. For this model I'd only have room for two at a time but I've done 4-6 things like that before without issues. I suppose I will look in to the splicing thing a bit though..probably not going to happen with the software itself it doesn't look like.
2012 M2 V4-PTFE
No, recall that the X gantry exists. Anything more than a few inches high will slam into that. Ask me how I know.
Think about it... (if were still talking about printing in vase mode for these vases) it would have to print a entire vase before moving to the next one. If your completed vase is anything more than say 1/2" high that completed vase is going to hit the vertical cross rail of the frame at some point during the start of that second vase no matter where it's located.
Unless of course you want to knock the completed vase off with the frame, hell then you can keep printing them all day long.
Edit - Now that I think about what you said .... Maybe if you did one at the front most part of the bed then moved to the back side it might work in theory I guess. Let us know how that goes.
jsc wrote:No, recall that the X gantry exists. Anything more than a few inches high will slam into that. Ask me how I know.
I've printed numerous jobs like this before, just not in vase mode.
If your first print is at the front, then it finishes and works towards the back, the first completed prints are forward of the gantry/extruder the whole time. Obviously you have to get your ducks in a row as far as making sure you load the models in the order you want them printed, and placement on the bed, but it's totally doable.
2012 M2 V4-PTFE
Hey, I have a deal. Give me the gcode for the vase in front and then another for the vase in back, and I'll combine it for you.
I have more or less the same thing to do, but they are widgets for a Chevy Pickup instead of vases. I notice in S3D you can duplicate the model Do a deselect both, then select each one and use the move, position or whatever they call it to change the locations of each of the widgets on the print bed. One at a time of course.
SO if I get them far enough apart they will print just one at a time? What if I printed on blue painters tape, (I use a PEI bed and PETG) and zip off the tape with the finished one. I am assuming I can pause the print and I do the SD card print. Suggestions?
swbluto wrote:Hey, I have a deal. Give me the gcode for the vase in front and then another for the vase in back, and I'll combine it for you.
Oh crap! I totally missed this. Too late now, I just did them one at a time, haha. But, on that note - is this something that's difficult to explain or to do as an example?
2012 M2 V4-PTFE
3dPrintingMD
Maybe I'm missing you here but, you just do the 1st model, get it to the size you want, etc. Then just copy and paste it, Ctrl + C, Crtl + V.wmgeorge wrote:I have more or less the same thing to do, but they are widgets for a Chevy Pickup instead of vases. I notice in S3D you can duplicate the model Do a deselect both, then select each one and use the move, position or whatever they call it to change the locations of each of the widgets on the print bed. One at a time of course.
Then you can just keep replicating the parts, and then client center and arrange, and it will put them on the bed for you, then you can see how many you can fit, and keep pasting them.
There is a selection in S3D that creates a duplicate model. I do not want to have the M2 trying to print both at the same time side by side because sooner or later the print head will crash into one or the other. I don't think the software knows it's going to happen.
I am planning on separating the two models far enough so one gets printed before the other, I know I can select the print order in the left side file menu. Hopefully no crashes. I hope I am on track on that part. Part 2 will printing on blue painters tape allow me to remove a finished part, before the bed cools...if I need to.
3dPrintingMD
I'm at a loss here.
I just looked at the duplicate models, and it does exactly what I indicated to do.
Its going to print a each of the models at the same time. So there is no chance they would crash into each other.
I'm actually printing out 4 of the same item right now.
