What is M302 undo command?
Lateralg
Post by Lateralg » Thu Jun 26, 2014 9:38 pm
M302 allows cold extrusion.
After sending M302, how do I return to normal?
Gary
Make Better Things
Make Things Better
Dale Reed
Re: What is M302 undo command?
Post by Dale Reed » Thu Jun 26, 2014 10:24 pm
Lateralg,
Couldn't find one on RepRap wiki or Marlin sites. I did find a firmware called "5DPrint" that uses M302 P1 to allow cold extrudes, and M302 P0 to disallow cold extrudes. I suppose you could try those commands and see what happens.... Maybe Marlin will incorporate (someday)?
Otherwise, I suppose you'll have to initiate a machine reboot or cycle power...
Post by Tim » Thu Jun 26, 2014 11:59 pm
The actual Marlin code for M302 is:
Code: Select all
    case 302: // allow cold extrudes, or set the minimum extrude temperature
          float temp = .0;
          if (code_seen('S')) temp=code_value();
      set_extrude_min_temp(temp);
    break;
So if you do just "M302", this is equivalent to "M302 S0", or allow extruding at any temperature above 0C.
If you want to return to normal, do for example "M302 S150", with S set to something slightly below your set temperature.
Dale Reed
Post by Dale Reed » Fri Jun 27, 2014 2:06 am
The source code!!! OF COURSE!!! I'll have to save a copy on my work PC so I can offer USEFUL responses when I sneak a look at the forum when I'm supposed to be working.... ;-)
Thanks, Tim!
sprior
Post by sprior » Fri Jun 27, 2014 2:25 am
Use The Source Luke!
