Lost my brim, or skirt when I downloaded the newest release.
The brim is necessary to me, because it primes the nozzle.
So, for now my S3D factory files will not print the skirt.
Consider this a bug and contacted support to let me know
how to fix, what wasn't broken until I downloaded the 2.1.2. version.
I'll keep you posted on what the issues are when their support tell me how to fix.
Here's what's in the new version:
Version 2.1.2
Added support for OS X 10.10 Yosemite
Improved Mac and Linux 250000 bps baud rate support
When using the Import button, the user can now select multiple files to load at once
Brim has been improved so that it remains attached to the part, even with support material enabled
Added support for up to 6 different extruders
Bed Leveling Wizard now supports a wider range of custom XY coordinates
Added pre-configured profiles for? edited as not to advertise other brands
Added the ability to remove multiple profiles at once
Filament cost calculations are now compatible with a wider range of currencies
Quality auto-configure XML tags can now be nested inside of material auto-configure tags to allow more detailed settings combinations
S3D new edition 2.1.2.
- Capt. John
- Contact:
Capt. John
Manistee, Michigan
Reel Amateur at 3D printing
http://www.michiganangler.com
Manistee, Michigan
Re: S3D new edition 2.1.2.
I've been using it for a few prints, and my skirts come out fine. I haven't tried a brim yet.
- Capt. John
- Contact:
New factory files I've made work fine.
It the older ones where I lose the skirts.
Support has not got back to me yet.
Capt. John
Manistee, Michigan
Manistee, Michigan
