Octoprint wont start my prints
Re: Octoprint wont start my prints
I reflashed the pi over the weekend and I'm still getting the same result. For those of you that have octoprint running what settings do you have in your printers profile?
Are you downloading...flashing the guy Sheffer version that is ready to run out of the box....???
i have had no issue with octoprint as far as running the printer. originally getting wifi working was another story. runs my printer great from mac or pc. it just uses the generic reprap profile. in the connection section mine says /dev/tty/ACM0. my baud rate is 115200. nothing special was set to run the m2. all my gcodes are made via s3d.
If you head over to http://octoprint.org/download/ and look at the link called Mirror #1 that is what I downloaded and flashed....twice. I'm at a loss here, it would be really nice if this thing would work, I'd sure like to be able to control extrusion / speed on the fly without having to leave my laptop hooked up.
Oh, have you tried not printing from SD? Try that.
Was there ever a solution to this? I just got my M2 and have printed off the SD card but can not get any of the controls to work through OctoPrint, even in the Control tab where you can manually move things around. I have reflashed a couple times and checked the check sum to make sure everything looked correct but nothing seems to work. Below is the out put of the terminal.
Send: G91
Recv: ok
Send: G1 X100.0000 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y-100.0000 F6000
Recv: ok
Send: G90
Recv: ok
Send: M105
Recv: ok T:27.3 /0.0 B:36.0 /0.0 T0:27.3 /0.0 @:0 B@:0
Send: G91
Recv: ok
Send: G1 X-100.0000 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Y100.0000 F6000
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z100.0000 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G1 Z-100.0000 F200
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G28 Z0
Any help would be greatly appreciated.
Thanks,
Jason
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: M105
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Recv: ok
Send: G90
Recv: ok
Send: G91
Recv: ok
Send: G28 Z0
Thanks,
Jason
I have this same problem on one of my M2's. I haven't figured it out so unfortunately I can't help but on mine it only happens when trying to print from the SD card in the M2. If I upload the files to the Pi it prints fine. Try uploading a file right to the pi and see what happens is the best I can offer.
