I am having trouble moving a sketch plane. I am drawing a bearing holder. At first I put a pocket 12mm diameter all the way through. Then I do a shoulder 14mm diameter going 4mm deep. I then decided to move the recess to the center. So I want to move the sketch associated with it an bring up the Placement window, the Translation window states X-0, y=-8 and z=0. I want to move it in 4mm, so I change y to -4 and hit apply. Nothing happpens. Hit Ok, go to edit the sketch and the plane is still on the face. It didn't move. Re-enter the Placement window and y is still -8.
How do I do this.
OS: Ubuntu 16.04.1 LTS
Word size of OS: 64-bit
Word size of FreeCAD: 64-bit
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
Qt version: 4.8.7
Coin version: 4.0.0a
OCC version: 6.8.0.oce-0.17
tj
Sketch plane placement
- Matt_Sharkey
Re: Sketch plane placement
for starters, what CAD software are you using?
also this should be posted on that CAD software's forums.
have you updated any extrusions that occur after the sketch you are modifying. You will want to check all subsequent actions to anything that modify.
