Anybody want to share slic3r profiles?
Post by insta » Thu Jun 01, 2017 7:42 pm
Looking at you, ed.
I don't care if you have custom gcode in the start or end, I know how to kajigger it.
Re: Anybody want to share slic3r profiles?
Post by ednisley » Fri Jun 02, 2017 1:17 am
insta wrote:Looking at you, ed
All I ever do is print a spool of PETG from one end to another, maybe with a few back-and-forth color changes, so I have exactly one profile that works for everything I print:
https://gist.github.com/ednisley/3e0076 ... 9a391dd332
The first three files contain settings for the printer, filament, and print, respectively. The last file is a Slic3r "config bundle", which contains a tweak for the lanyard reel (*) I made a while ago; I sometimes save a tweaked configuration during a long-running project, but I rarely make more than one of anything.
You use more different filaments than I have t-shirts, so (most likely) you already have a PETG config just like it and should write a book about filament settings. [grin]
(*) Which eventually turned out great, if you happen to like how 3D printed things look:
https://softsolder.com/2017/04/28/badge ... eel-mount/
