Octoprint damaged - how do I re-install?
wbp
Post by wbp » Mon Sep 03, 2018 9:20 pm
I have an M3ID which came with Octoprint installed on a Raspberry Pi. The Octoprint s/w has become damaged, it no longer functions correctly. Apparently this sometimes happens if an update gets corrupted somehow. I can no longer run the MakerGear Setup, it just hangs with "Loading", and I cannot enable SSH to get to the Pi and try to resolve it. For the normal OctoPi there is an SD card image download, but this does not have the customization for the M3ID. Where can I find an image that I can download so I can re-install the Pi?
(I opened up a support ticket 2 days ago but no one is responding)
Thanks,
Will
Re: Octoprint damaged - how do I re-install?
Post by airscapes » Mon Sep 03, 2018 11:25 pm
Give it a day or so.. holiday weekend and all!
Post by sthone » Tue Sep 04, 2018 12:40 am
You can try the Makergear Github page I know there is some Octoprint stuff there but I've never looked at it so I'm not sure if its what you need or not.
makeal
Post by makeal » Sat Sep 08, 2018 5:47 pm
You can download octopi image then install makergear plugin and it turns regular octoprint into makergear octoprint.
once you are up and running with octoprint go into plugin manager and install via url. Point to this https://github.com/MakerGear/MakerGear_ ... master.zip
after installation reboot the pi. I would switch the micro sd card so you can preserve the one that came with M3 and just load octopi on to new sd card
