8.3 naming convention
Posted: Tue Apr 22, 2014 12:08 pm
I wasn't sure if everyone already knew about the 8.3 naming convention causing print names to show up with a "~" in the "print from sd" menu, but I thought I'd share how I've worked around it.
I have a lot of print files, many with different copies of objects and it gets hard to keep the names straight on the SD card. Harder still when S3D defaults to naming files *.gcode
The 5 letter file extension doesn't play well with the way the M2 reads the SD card, so if you want your file names to show up correctly, just rename them on the card from a .gcode file to a .g file.
You can do this to all files in a directory at one time using DOS commands from the command prompt. Just enter command prompt, navigate to the directory where the files are located and type REN *.GCODE *.G
You still have to keep the name to 8 characters or less, but it helps if you have lot of files.
