v4 Hot End Indicator Mount
Slipshine
Post by Slipshine » Sat Apr 25, 2015 8:09 pm
I just finished putting in my v4 Hot end upgrade and discovered the most wonderful thing.
Their is a indicator mount built right in to the hot end holder.
if you take out the clamp screw and use a longer one you can mount an indicator right in the thread clearance hole.
A little better look
Indicator
m2 indicator.jpg (161.72 KiB) Viewed 23884 times
Close UP
m2 indicator-2.jpg (120.14 KiB) Viewed 23884 times
Slipshine
Re: v4 Hot End Indicator Mount
Post by Slipshine » Sat Apr 25, 2015 8:14 pm
First Calibration cube with v4 hot end. Man is that thing stable.
calibration cube .25 layer
m2 CUBE.jpg (98.62 KiB) Viewed 23880 times
thunderbt3
Post by thunderbt3 » Sun Apr 26, 2015 2:15 am
Looks like the newer V4 mounts are anodized black. The first run of them were not anodized.
dklassen
Post by dklassen » Sun May 08, 2016 2:45 am
Deleted
3dPrintingMD
Post by 3dPrintingMD » Mon May 09, 2016 2:41 pm
Great idea. I have a dial like that, which is way more accurate than the one I have been using, going to give this a try, because I keep running into issues where I am not level.
Post by Jules » Mon May 09, 2016 3:11 pm
That is another "poster boy" for calibration cubes! (Ed and Jin also posted a couple.) Looks great! :D
Ryan_
Post by Ryan_ » Tue May 10, 2016 4:04 am
Great idea. These lever style dial indicators require less force than plunger style indicators, so they shouldn't compress the bed's springs and give a false reading.
zemlin
Post by zemlin » Tue May 10, 2016 12:23 pm
Ryan_ wrote:Great idea. These lever style dial indicators require less force than plunger style indicators, so they shouldn't compress the bed's springs and give a false reading.
I removed the spring from the plunger in my cheapo indicator. Since gravity always works in the right direction, it's not needed here. It was just a small extension spring out in plain view behind the back plate.
dklassen
Post by dklassen » Sun May 22, 2016 10:45 pm
Worked like a charm!
Matt_Sharkey
Post by Matt_Sharkey » Mon May 23, 2016 1:11 am
Would I need a high quality indicator for leveling the bed? I was hoping to just buy one of these:
http://www.amazon.com/Surface-Smoothnes ... =indicator
