insta wrote:Get one of the all-in-one $35 PID controller kits off of eBay.
Absolutely!
Buy the biggest blocks you can, wire 'em together, and don't putz around with circuit design & DIY Arduino sketches. This stuff is dirt-cheap on eBay / Amazon, so if your time is worth more than $0/hr, everybody comes out ahead.
insta wrote:a relay inside that'll do 120v @ 10A
Mechanical relays have both an AC rating and a DC rating. If you believe the eBay specs for that controller:
Usually, the AC current rating will be higher than the DC rating, because they use the zero crossings to extinguish the contact arc. In this case, they're the same, which puts an orange flag on the specs.
In any event, that's much much
much less than you need for a heated build platform. Switching the platform through an outboard DC-
DC (not the usual DC-
AC) solid state relay would be a Very Good Idea, because it removes the mystery specs from the design:
http://www.ebay.com/itm/1pcs-Soild-Stat ... 0737814413
Whatever the 24 V platform current might be (one measurement trumps one kilo-opinion), get an SSR rated at twice that value.
The thermocouple attaches to that controller through screw terminals, not a Type K connector, so you must figure out the polarity on your own: if the temperature reading makes no sense, swap the connections. Better yet, get a sack of female Type K connectors:
http://www.ebay.com/itm/5X-New-Female-K ... 1508059056
Wire one up appropriately and you have a no-goof connection for standard thermocouples.
