simplify3d v3.0
Re: simplify3d v3.0
Post by insta » Wed Jul 08, 2015 9:39 pm
... I may also have different ideas for what's an acceptable way to treat the machine and the expectations for it.
PcS
Re: simplify3d v3.0
Post by PcS » Thu Jul 09, 2015 12:53 am
I doubt it !!! lol I want to run as fast as I can and still get good prints.
Re: simplify3d v3.0
Post by jimc » Thu Jul 09, 2015 1:11 am
if no one has found this, simplify 3d has a you tube channel. they have a bunch of new videos there showing new features.
https://www.youtube.com/channel/UCQP0Ku ... TbLVYWZXnQ
Re: simplify3d v3.0
Post by jsc » Thu Jul 09, 2015 3:45 am
If you haven't tried this yet, turn on Perform retraction during wipe movement under Advanced and print out a cylindrical object. Gives a fantastic seam. It's not completely invisible, but to my eye it is much improved.
PcS
Re: simplify3d v3.0
Post by PcS » Thu Jul 09, 2015 11:58 am
jsc wrote:If you haven't tried this yet, turn on Perform retraction during wipe movement under Advanced and print out a cylindrical object. Gives a fantastic seam. It's not completely invisible, but to my eye it is much improved.
I have been using this on all prints and it really seams...lol to help !!!
PcS
Re: simplify3d v3.0
Post by PcS » Thu Jul 09, 2015 3:36 pm
Upped to 250 and y axis skipped guess I'm stuck at 200 it runs beautifully at 200 and 60mms print speed petg 100 percent infill width.
Bratag
Re: simplify3d v3.0
Post by Bratag » Thu Jul 09, 2015 7:47 pm
insta wrote:
PcS wrote:Personally I have never been able to just run the s3d files as is. They default to running the m2 too fast and I always have to lower the x y speed or else risk skipping steps. I wish they would change the default as it seems a lot of other users have seen the same.
I just covered my rails in motor oil, and now I print at 140mm/sec for PLA, with 250mm/sec travel moves. The M2 is beefy, use it ;)
i run 1200 accel on the dual, and 1800 on the singles though
140? Cripes I thought I was being risky when I upped my speed to 90mm/s print speed.
Whats the ringing/detail like at that speed?
Re: simplify3d v3.0
Post by insta » Thu Jul 09, 2015 8:45 pm
It doesn't ring too badly, not sure why mine's a magic snowflake. The people I'm printing for don't care though.
The v4 seems to cut down on it some, the all aluminum construction flexes less than the ABS & PEEK holding in the brass barrels. I also run a low acceleration.
Ronnien55
Re: simplify3d v3.0
Post by Ronnien55 » Fri Jul 10, 2015 3:39 pm
Hey all can someone help me or explain this: Under the Advanced Tab there is the tool change retraction. It does not seam to work correctly. I cannot input a negative tool retraction only positive, but retract is a negative number not positive. the restart distance can be positive or negative all though i do not understand retracting when you are trying to extrude what you retracted. Am i looking at they wrong or is there a mistake in values in this section?
sprior
Re: simplify3d v3.0
Post by sprior » Fri Jul 10, 2015 4:01 pm
Tool change retract can only mean sucking the filament back into the nozzle a little so from your perspective it's an inherently negative value, but then a positive value would make no sense so the parameter is specified unsigned.
