sckibbons
Post
by sckibbons » Fri Jul 31, 2015 1:44 pm
Hi All,
I recently upgraded my M2 to the Dual v4 Extruder setup. I'm only using the left nozzle at this time but i noticed a big difference is the print quality using the same Slic3r settings as i was with the older v3b extruder (see picture). I'm fairly certain the bed is properly leveled but i'm not sure what else could be the cause.
Any help would be greatly appreciated.
- Print Quality (v3b vs v4 dual)
- Print Quality.jpg (102.26 KiB) Viewed 12559 times
Matt_Sharkey
Post
by Matt_Sharkey » Fri Jul 31, 2015 1:51 pm
More details on what you have done for calibration?
adjusted your multiplier?
Z-Offset adjusted?
sckibbons
Post
by sckibbons » Fri Jul 31, 2015 2:07 pm
Should i reduce the multiplier or increase it? i think it was set to 1.0 in this photo but I was thinking about changing it to 0.95. The z offset is set to 2mm but should i decrease it to 1mm?
sckibbons
Post
by sckibbons » Fri Jul 31, 2015 2:26 pm
This is Awesome. Get to pull out the ol' calipers tonight!
Thanks!!
Matt_Sharkey
Post
by Matt_Sharkey » Fri Jul 31, 2015 2:27 pm
yeah pull them out and keep them handy. Dusty calipers are wasted calipers
Post
by jimc » Fri Jul 31, 2015 2:32 pm
Yes its a totally different hot end setup. Your v3b settings wont work. Everything needs to be retuned for the v4.
Post
by jimc » Fri Jul 31, 2015 3:50 pm
The sluc3r user base in the m2 crowd is a bit limited. I have no info for you on it. I only use s3d
PcS
Post
by PcS » Fri Jul 31, 2015 5:17 pm
Temps are different between the two aren't they ? Seems like some people had to change printing temperatures slightly. My v4 I run pla at 180 . On the v3b it was 210.
