Rara
Post
by Rara » Fri Jul 31, 2015 3:23 am
Oh my. Well, let's see what we can do
now.
2012 M2 V4-PTFE
Post
by Jules » Fri Jul 31, 2015 3:29 am
Rara wrote:Oh my. Well, let's see what we can do
now.
Don't feel too bad....
"I" forgot to include the information in the write-up! (Triple whoopsie!)
Post
by jimc » Fri Jul 31, 2015 3:37 am
i have a spool of this here. i did some of the testing on it awhile back and it seemed very nice. ill give a report once i have some settings and print time with it. its a modified polycarb.
also got a spool of the opaque red petg as well
Rara
Post
by Rara » Fri Jul 31, 2015 3:42 am
Oh really? Haha, I was like...how did I manage to miss an entire section!
Anyway, another print going right now, let's see how this goes (different part, but I printed one with the old profile too).
2012 M2 V4-PTFE
Rara
Post
by Rara » Fri Jul 31, 2015 10:02 pm
WOW. Wow. That made a HUGE difference..thank you guys so much for catching that! My test print looks just as good as one I made of PLA a while back, literally one or two strings on the outside, and the (4) through holes came out perfectly clean. This might be the all-around, general purpose filament I've been hoping for.
Next up will be improving the surface of supported areas, and I had a test set up...except my extruder motor mount just cracked in half..and I am an idiot who never printed myself any spare parts over 3 years. Field repair time! Are there any improved from stock versions or is the R2 version the best bet?
2012 M2 V4-PTFE
Matt_Sharkey
Post
by Matt_Sharkey » Fri Jul 31, 2015 10:29 pm
Rara wrote:...except my extruder motor mount just cracked in half..and I am an idiot who never printed myself any spare parts over 3 years. Field repair time! Are there any improved from stock versions or is the R2 version the best bet?
I was in your shoes last year and insta helped me out, so I'll offer you the same.
- 20150731_212714416_iOS.JPG (508.33 KiB) Viewed 14086 times
10 dollars shipped.
Post
by jimc » Fri Jul 31, 2015 10:36 pm
take some acetone or epoxy and glue yours back together so you can print another. here is an stl for a beefier extruder mount without the hole where it commonly cracks. print this abs at 70-80% infill. i have never broken one of these.
Matt_Sharkey
Post
by Matt_Sharkey » Fri Jul 31, 2015 10:42 pm
on top of the acetone, put a hefty zip tie (or two) around the whole mount, for good measure
Rara
Post
by Rara » Fri Jul 31, 2015 10:49 pm
Turns out I had this tiny little C-Clamp at the bottom of my tool box that was perfect band-aid. No muss, fuss or waiting! Thanks for the quick aid though, much appreciated.
Interesting though, as I think we might be getting to the point where metal may be appropriate with the V4 since the motor and hot end are now divorced; you can see and feel the motor mount flex in the Y-plane when it's transitioning between extrude and retract (now that I have functioning amounts of retraction
). Mounting bolts were tight (mount broke when I was putting the motor back on after checking as it were), only thing it could be is the plastic deflecting.
2012 M2 V4-PTFE
Matt_Sharkey
Post
by Matt_Sharkey » Fri Jul 31, 2015 11:01 pm
Rara wrote:Interesting though, as I think we might be getting to the point where metal may be appropriate with the V4 since the motor and hot end are now divorced; you can see and feel the motor mount flex in the Y-plane when it's transitioning between extrude and retract (now that I have functioning amounts of retraction
90% infill might be as good as metal
