Second biggest thing is that if you use a shield on it, attach a hefty brim to the shield. They tend to pop off about halfway into your fifth layer otherwise.
If the shield is too far away from the object, (as it tends to be for a twisting vase that's narrower at the bottom than the top), it has limited effectiveness and i got a few dribbles on the print at one point, but the shield is pretty effective: 'Bout halfway through, lots of oozes caught: Mount Vesuvius: And the unveiling....only problem was the shield got a little to close to the print on one edge and stuck a few fibers to the print. They pulled right off though, so it worked pretty well. Overall, not too shabby for the "mostly default" S3D settings with a little fine tuning.
(Thought folks thinking of getting a dual might want to see a bit of the process in pictures.)
