HPB problems
TheRyanRanch
HPB problems
Post by TheRyanRanch » Wed Oct 21, 2015 6:07 am
anyone run into this on their M2 ?
heated bed fail.JPG (37.12 KiB) Viewed 14581 times
It's obvious why it's not working, Cant figure out how this happened :shock:
Kulturfolger
Re: HPB problems
Post by Kulturfolger » Wed Oct 21, 2015 9:35 am
Its broken by mechanical stress. To much bending. In my eyes this is the best solution: http://www.thingiverse.com/thing:1001793
In the meantime just remove the complete sleeve and replace the wires.
SouthSideofdaSky
Re: HPB problems
Post by SouthSideofdaSky » Wed Oct 21, 2015 12:25 pm
Yes, the wire experienced fatigue stresses and eventually failed over time from the back and forth motion. I think this is a fairly common problem - mine did the same thing a month or so ago.
You could print something, but I think my solution was better...I contacted MakerGear about getting/buying a replacement and they sent me one. The new one I received has a stronger wire design which eliminates this problem.
In the meantime, you can attempt to solder it back together (if you have the tools) or do something else along those lines like Kulturfolger said. Also zip tie the wire to the metal spider piece to reduce stresses.
viewtopic.php?f=7&t=1712
TheRyanRanch
Re: HPB problems
Post by TheRyanRanch » Wed Oct 21, 2015 6:53 pm
SouthSideofdaSky wrote:Yes, the wire experienced fatigue stresses and eventually failed over time from the back and forth motion. I think this is a fairly common problem - mine did the same thing a month or so ago.
I wound up soldering it back together, the weird thing is I can't find the "Heated Platform" as a spare part to buy...... :o
Re: HPB problems
Post by insta » Wed Oct 21, 2015 7:17 pm
Email support [at] makergear [dot] com, that's how you get any random part of the machine.
SouthSideofdaSky
Re: HPB problems
Post by SouthSideofdaSky » Thu Oct 22, 2015 12:44 pm
TheRyanRanch wrote:I wound up soldering it back together, the weird thing is I can't find the "Heated Platform" as a spare part to buy...... :o
insta wrote:Email support [at] makergear [dot] com, that's how you get any random part of the machine.
Yes, I couldn't find it either which is why I had to email support. Sorry, should have been more clear about that in my previous post. They sent me a new one with the revamped wire/connection design and it arrived within a week.
thunderbt3
Re: HPB problems
Post by thunderbt3 » Thu Oct 22, 2015 1:43 pm
What does the new style look like?
3dPrintingMD
Re: HPB problems
Post by 3dPrintingMD » Fri Oct 23, 2015 4:14 am
I just looked the new style has a loop/circle at the end of the bed, the cable which is inside a wire loop goes thru the hole. Essentially supporting the wire, much better design.
I would think it could be added to any bed, they just drilled two holes in the bed, countersunk, and attached the "loop" on the bottom.
Re: HPB problems
Post by insta » Fri Oct 23, 2015 5:10 am
Picture?
SouthSideofdaSky
Re: HPB problems
Post by SouthSideofdaSky » Fri Oct 23, 2015 1:05 pm
Here is a picture of what the new connection/wire design looks like (sorry, was in mid-print yesterday :D )
New HBP design
