Comments on (sorta) high volume FDM printing
Re: Comments on (sorta) high volume FDM printing
Also try upping retraction to 1mm (reduced stringing, if that's an issue) and .1-.2 mm of negative extra length on restart (reduced blobbing).
Turns out there is a way to convince slic3r to print objects in _your_ order.
On the right side of the plater tab there is a list of objects. It appears slic3r obligingly prints these in order top to bottom. Shazam .
Simply add your objects to the plater, click the arrange button and away you go!
This should solve my problems. The 1 at a time results are far superior to the 4 at a time results.
bignordique
bignordique
I vaguely recall arranging a bunch of things-to-print on the grid, then having Slic3r go "Wooga!" and rearrange them when I added a thing I'd forgotten. Might have had auto-arrange checked or (more likely) perpetrated a finger fumble, and it probably didn't change the list on the side, but ... check twice, print once, every time!bignordique wrote:slic3r obligingly prints these in order top to bottom
Dude, cast those in resin. Hands down.
I've considered something like that... but frankly don't know/have that capability. Trying to brute force it out with something that's mostly working.insta wrote:Dude, cast those in resin. Hands down.
Having said that, can you give me a pointer on how I might go about giving casting a good evaluation?
Thanks.
bignordique
Send me the STL ... I do a lot of casting and can give you a quick yay/nay on if it's beginner friendly.
