Well that's the thing... I did use 5 layers of top infill. I confirmed in S3D's preview that all 5 layers were there. And yet I still get the holes.Jules wrote:If you're going to use only 15% infill, you want to use at least 4 or 5 top layers. (Those holes sometimes form over skimpy infill, you need enough top layers to make sure it gets filled in.) Am I printing the infill too fast? It's on the default 80mm/s, and it's fine when it lays down the layers on the build plate, but it gets iffy when it prints on top of any infill.
Bottom layer looks fine - might be a bit over-extruded, but that's better than not enough.
I have something printing now, but I'll get to the hollow box test model afterwards. I tweaked some settings for the current thing printing: 8mm/s outlines, 25% fast hex infill, and .2mm vertical ret. lift for .1mm layer height. It's doing great so far, very very little ghosting around the corners (
By the way, here's the rest of the plane I'm printing. Only the wings left to print.
