Z offset
Z offset
I love the M2. I get great prints but I need to re level everytime I change my blue tape. This really drove me nuts until I stumble on a system that works for me. My question is, Is there a specialty wrench I can buy that lets me adjust the Z offset without cursing the lack of space to do this task?
Re: Z offset
You actually don't have to change the Z-Stop (which is what you're doing) every time if you just adjust the Z-Offset in the software when you change out the tape. It's a whole lot easier and just requires printing a couple of calibration squares.
Instructions here:
viewtopic.php?f=3&t=3124
But if you absolutely want to keep changing the Z-stop, I like to use this:
http://www.thingiverse.com/thing:198811
Instructions here:
Re: Z offset
Undo the entire nut/bolt assembly and reassemble it with the nut on the underside of the spider (but the bolt head still on top).
Relevel your bed, but this time jack the screws down as tight as they go and loosen them to level, instead of the other way around.
Re: Z offset
On the v4, you can just loosen the nozzle screw and drop it down to your surface. Use a shim to get the separation you like. Use gcode z-offset to fine tune if necessary.
Re: Z offset
This is definitely not the *right* way, but if you need a quick hack to "raise" your bolt, I have...uh... stuck little pieces of painters tape on top of my bolt until I got it to where I wanted. : )
Re: Z offset
Hell... thats not a bad IdeaTGAW wrote:This is definitely not the *right* way, but if you need a quick hack to "raise" your bolt, I have...uh... stuck little pieces of painters tape on top of my bolt until I got it to where I wanted. : )
