eSUN PETG Problem
eSUN PETG Problem
I attempted to utilize eSUN red and blue PETG following Jules' post about eSUN black as a reference for settings, but the following picture illustrates what is happening a few minutes into the print. I have never had this problem with PLA or ABS. What is the cause and fix? Thanks.
Re: eSUN PETG Problem
Looks like it jammed and stripped. Check your Filament Drive Screw tension.
viewtopic.php?f=3&t=2694
It seems the problem is fixed, but will print some more tomorrow to make sure. I adjusted temp on extruder, slowed down the speed, and adjusted drive screw tension, so essentially trial and error. Thanks.
