change filling factor in some regions
boep777
Post by boep777 » Sat Apr 23, 2016 12:59 am
Hi everybody, how do you solve this type of problems:
I have a pedestal and a thin object coming out on sharp angle (for example a leg). I am printing with low infill.
Simplify3D algorithm makes the interface between pedestal and object using infill. Which is correct, but very weak and frequently broken.
So it would be cool to say to software to make solid fill around the area. But such an option does not exist - what would you do ?
Thanx!
Re: change filling factor in some regions
Post by jsc » Sat Apr 23, 2016 1:51 am
The most common way to have different infill densities for different parts is to differentiate by layer. I don't think any current slicer allows you to set arbitrary densitives for different 3D areas. https://www.simplify3d.com/support/tuto ... f-a-model/
Matt_Sharkey
Post by Matt_Sharkey » Sat Apr 23, 2016 2:41 am
jsc wrote:The most common way to have different infill densities for different parts is to differentiate by layer. I don't think any current slicer allows you to set arbitrary densitives for different 3D areas. https://www.simplify3d.com/support/tuto ... f-a-model/
Slic3r will allow you to set arbitrary settings for specified areas. you do this by applying a Mesh Modifier.
-take your STL into a CAD software
-add an accompaning volume that describes the region that would follow a different set of rules
-in slicer, double click on the STL in question, load the modifier mesh and set the specific settings.
Photo toutorial with TinkerCAD and Slic3r:
Some Sample 3D model
Add the volume that you want to modify
separate out the 3D model to save the modifier mesh
load in Slic3r and double click to get model specific options.
Add Modifier mesh and set the specific settings
Matt_Sharkey
Post by Matt_Sharkey » Sat Apr 23, 2016 2:52 am
and finally the result:
End result of applying the modifier mesh
Post by Jules » Sat Apr 23, 2016 3:38 am
I think you can do that in S3D as well, by portioning the design into parts before printing, and then assigning different Processes to each part. (No I've never tried it....jin could probably walk you through it.)
