I tripped over the perfect tool for prying up prints when I grabbed the wrong tool from the pile and got to work.
It's a plastic scoring tool by Hyde - very inexpensive, and it has a strong honed edge. I'll attach the link below.
Newbies, you use this at one tiny corner to gently pry up the very edge, just to break the seal, and then you insert a thin dull spatula underneath it to gently work the print up after you have broken the seal. It's got a sharp enough edge that you can get it underneath the print pretty easily, and it's not as fragile as a knife or razor blade, and won't bend.
But the plate surface needs to be fairly stable and firm, so PEI (the heavy kind, 0.03inch), MIC6, or glass if you are careful, would be good surfaces to try it on. (It's not gonna work on tape or films of any kind....you'll gouge it. And I wouldn't use it on a Zebra either.)
https://www.amazon.com/Hyde-Tools-45730 ... 000C027ZE/
Probably cheaper at the hardware store if you can remember to pick one up next trip.
